'Blueprinting' a Jetex Carb
soosh
dennis wrote: seems to me it's just luck with any carb.
Depends what you buy,never needed luck when buying/using a PHBH Dellorto.Most reliable carb for a scooter out the box ive ever found and easy to spec.
soosh
A jetex carb delicately being blueprinted....
Spanish Fly
Main scooter: P200e
Lamaddict wrote:Could someone please list the things you have to do to check and mod a Jetex 22 carb to work and perform properly.
According to Allstyles;
Jetex 22mm Carb Modified. Ref: 1054
* IN HOUSE MODIFICATION FOR BETTER RUNNING
* JETS CHANGED TO ITALIAN
* ATOMIZER MACHINED & MODIFIED
* HOUSING MODIFIED
cit205
soosh wrote:A jetex carb delicately being blueprinted....
:lol: :lol:
tonydevon
Main scooter: '71 GP125
ha ha that pics great
the GP I just bought was fitted with a jetex 22mm, while sorting through the boxes of spares I found another brand new boxed, asked the seller why 2, he said that he was told they were rubbish so bought 2, 1 as a spare????
just no reasoning with some people LOL
both will be "blueprinted" as per above instructions, 28mm dellorto gone in its place
dennis
Main scooter: 1 gp 1 special
ok whatever,everyone to there own, i'll stick with the jetex till it goes wrong then try a PHBH but i expect that will make a bigger splash.
Muppet
Jettex are crap is 10% fact with 90% snob value saying Italiano is best
C’est la vie
nelson pk
Will a jetex work out of the box on a standard Lammy?............probably.
Is it as good a carb compared to PHBH and other aftermarket ones?..........feck, no!
Would i run one on a tuned machine?...................you must be joking!
Would i run one ever again, at all?......................nope.
I don't think it's snobbery as i wouldn't run a standard Dellorto 22mm carb either! Its a very basic design carb.
nelson pk wrote:I don't think it's snobbery as i wouldn't run a standard Dellorto 22mm carb either! Its a very basic design carb.
That's as may be, but that's the strength of it. I can cheerfully take one to bits and swap jets with a good probability of getting it right. I could just as easily do that on the side of the road as I could in a workshop. While the modern PHBL, or whatever is undoubtedly a good carb I'm not sure you can say the same about it. There always seems to be to many variables to me and it needs too much setting up.
scooterslag
Yeah that's one of the things I love about standard set-ups, the jetex thing does seem a pot-luck thing similar to some electronic flywheels on the market- some are good, quite a few are gash. Can't be f@@ked to either waste my time and money on finding out if I've got a good one. :ninja:
The mack daddy on the left!
    Users browsing this forum: Ahrefs [Bot] and 17 guests
