Hello everyone,
I've gathered all torque info on Lambrettas as well as Vespas in this public spreadsheet:
https://docs.google.com/spreadsheet/ccc ... 0xxY3lqLUE
Since I've made it public anyone can update it, and it's my hope that the document becomes a collaborative effort where everyone fills in missing data and takes the responsibility to keep it up to date.
But remember that with great powers comes great responsibility, so please don't do anything silly.
It can easily be printed or downloaded as a PDF for readily access to while in the shed.
PM me if any comments or suggestions, and moderators let me know if this shouldn't be the right section.
Vespa & Lambretta torque information
warts
- registered user
- Main scooter: honda
- Contact:
Would a separate section on std torque values for common thread sizes be useful? You know, the ones people give that bit extra for "luck".
I'm out the country for a while, so can't copy in the (paper)ones I have.
Here's one;-
http://www.npfasteners.com/pdfs/max-rec ... torque.pdf
but only in Nm's - NFG for my torque wrench.
Here's one;-
- Toddy
- registered user
- Main scooter: Lambretta Series 1
- Contact:
victor wrote:Hello everyone,
Cant see it ??
- victor
- registered user
- Main scooter: Tv175 but currently a SS210 :)
- Contact:
Probably your web browser is cutting the url - try this shorter version: http://bit.ly/VIKpBSToddy wrote:Cant see it ??victor wrote: https://docs.google.com/spreadsheet/ccc ... 0xxY3lqLUE
- victor
- registered user
- Contact:
Absolutely, it's easy to create a new sheet in the document, or send me the data and I can do it.warts wrote:Would a separate section on std torque values for common thread sizes be useful? You know, the ones people give that bit extra for "luck".
Here's one;-
What will be needed is:
Steel bolt - steel nut/goods
Dimension - thread length - torque
(M5 - 20mm - 10Nm)
(M5 - 25mm - 12Nm etc)
Steel bolt - alu goods
Doesnt matter which standard (international Nm or imperial pound-foot) as the spreadsheet can recalculate that.
warts
- registered user
- Contact:
As said, on hols for next four weeks, French gite has internet, but very slow and the info is at home anyway.
If no one else posts in meantime, I may forget so send me a reminder in a month or so.
