'Blueprinting' a Jetex Carb
Could someone please list the things you have to do to check and mod a Jetex 22 carb to work and perform properly.
- Main scooter: Lambretta
1 - Check it doesn't have Jetex written on it
2 - Go to 1
2 - Go to 1
rosscla wrote:1 - Check it doesn't have Jetex written on it
2 - Go to 1
Minority
- Main scooter: Li230 S3
I was waiting for someone to say "throw it in the bin"bsso78 wrote:rosscla wrote:1 - Check it doesn't have Jetex written on it
2 - Go to 1![]()
(no personal experience mind you)
- Toddy
- Main scooter: Lambretta Series 1
Agree with all the comments ive had good and bad jettex carbs , what do you want to Mod it to run on ? there are different slides and atomisers for 150 / 200
Donnie
- Main scooter: Lambretta Eibar Series 2
Not the ones I've had. As I say, treated right and not bought from some dodgy ebay seller direct from india and a change of the jets and they've given perfectly good service.soosh wrote:And change the body and slide.Donnie wrote:Never had any issues with the few I've owned once u swap the jets for genuine dellorto ones.
Donnie.
dennis
- Main scooter: 1 gp 1 special
Got to agree with Donnie, the jetex i run goes well even without changing the jets, you say jetex are crap, have a look on carb set ups on this forum to see who's having the most problems after they have binned the jetex, seems to me it's just luck with any carb.
haven't owned one myself but problems i have come accross only relate to poor quality control
check float operates freely ( remove flash from body and float )
float needle damaged on almost new carb
jets and atomisers aren't always the same size or machined the same, although marked the same
