fittment off sip pick up speedo sensor pictures
simonwwfc
my sip speedo pick up sensor has just arrived with a tiny magnet and would just like to see how this is fitted please if possible as ive done away with drum on front and have disc conversion . where have you guys got it fitted thanks piccys please
freestone71
Main scooter: li150 special with ts1225
i stuck it on the hub where it sticks out for the bearing to go in if that makes sense , good blob of araldite under it.
simonwwfc
freestone71 wrote:i stuck it on the hub where it sticks out for the bearing to go in if that makes sense , good blob of araldite under it.
how does the sensor itself fit ?
Minority
Main scooter: Li230 S3
If you have the active sensor, which I believe you do, you don't need the magnet. The sensor will pickup a bolt head moving past and the bolts that hold the disk to the hub are ideal for this. The official bracket to mount the sensor is this one:
http://www.sip-scootershop.com/en/produ ... obi002s08n
You can see it in action on Edens scooter in this post http://scooterotica.org/forum/viewtopic ... 4&start=10
and you could probably fit it so the sensor goes through the lower hole in your caliper bracket to pick up the disc bolts.
Now you have gone down the sensor route, not only can you get rid of the speedo cable but also the speedo drive housing and gear (using a suitable spacer to replace the housing to keep everything lined up). I did on mine and I like the cleaned up look.
simonwwfc
great so they sold me a magnet and active speed sensor and they didnt bloody tell me i needed a bracket my sensor is part number KOBF640JO2 SA07 ??
http://www.sip-scootershop.com/en/produ ... sa07+_kobf
what have you got your bgm`s setting on ?
also where did you get your cable clip from that holds brake hose im desp after 1
Minority
Yes, I was sure this was thoroughly covered, keep up Simon :lol:
Minority
simonwwfc wrote:great so they sold me a magnet and active speed sensor and they didnt bloody tell me i needed a bracket my sensor is part number KOBF640JO2 SA07 ??
Well you may not have needed a bracket, I didn't, I made my own.
Don't know what my BGMs are set to, whatever they were when I got the scooter :biggrin:
simonwwfc
bloody bracket came but grub screw missing . fitting tomorrow eve il let u no how it goes ;)
Minority wrote: If you have the active sensor, which I believe you do, you don't need the magnet. The sensor will pickup a bolt head moving past and the bolts that hold the disk to the hub are ideal for this.
Resurrecting this as I've fitted the speedo using the cable, interested in using the active sensor I have. I understand the hub end using bolts or magnets, but how do you set the speedo itself for this input, and whether using 1 magnet or 4 studs etc.?
    Users browsing this forum: Google [Bot], Semrush [Bot] and 90 guests
