You're right, I stand corrected. Since the odds of sucking a small bird into your engine is small, it's not worth the drop in performance to run an air filter.soosh wrote:You heard of anyone getting a small bird sucked into an engine?RManson wrote:
I'd take the drop in performance that adding an air filter might present over running the risk of sucking in a small bird through the inlet and grenading the engine. Cheap insurance and all that.
-Ryan
air filter or not
Adam_Winstone
- Main scooter: Lambretta GP
... and let's face it, who wants sores, discharge, weeping, itching, burrowing parasites and the possible death of piston, bore or crank?!Andy Pickering wrote:Theirs a sort of parallel with sex really when you think about it
Condom or bare back?
Although, if I could get my scoots to reproduce
I know someone who demolished a ts1 when the flat clip holding the gp plastic panel embelisher got sucked into an open mouth carb ,its not a small bird but what are the chances.....filter for me
We spent 4 hours in a remote lane in France last year dismantling and reassembling mate's TS1 ,turned out it had sucked in one of those small road stones that cover resurfaced roads into the open carb . It had full panel work too
tonydevon
- Main scooter: '71 GP125
yup its things like that which worried me.
my carpark at home is tarmaced and covered in a thin layer of tiny white stones, then theres the amount of sand that blows around as Im by the beach, so if I have to lose some power then so be it
I just cant afford to lose any money!
- sean brady scooters
- Dealer
a good compromise between the two options (open or filter) is to fit a fine mesh gauze wire like the household seive type .
this keeps up air flow and performance whilst stopping bigger objects from entering the carb
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 6 guests
