winter rebuild
thanks ..found his site now ..looks like 50mm to order but would be spot on for mounting water pump i think
martinr
wheels done .arse of a job that is
martinr
bit more done
martinr
front and rear brakes done
Stokie
Is there a reason why the rear disc caliper has to be in that position? Could it not be mounted on top or at say 3 o'clock and give better ground clearance and run a shorter hose?
Junglemod
Main scooter: 62 series 3 li
Nice work there mate !!!!!
Hope you've got a heater in that shed ,nice work space for a rebuild.
tonydevon
Main scooter: '71 GP125
cool build
where did you get the front shocks?
martinr
cheers chaps theres quite a lot of ground clearance it looks closer in the pics 8-) .the front shock are from frank sanderson then i got the springs powder coated orange
Looking very nice are the floorboard runners laser cut ?
Toddy wrote:Looking very nice are the floorboard runners laser cut ?
Been thinking along the same lines myself :D, with grip tape underneath and patterns similar to the pinstriping that Col did on the paint, what have you used Martin 2mm brushed ally or S/S.
    Users browsing this forum: Majestic-12 [Bot] and 28 guests
