Clutchnut on P200
chrisM
Main scooter: Vespa GS 200
I'm struggeling to loosen the (old style castlenut-type) clutch, although I use the proper castlenut-type socket.
My stupid question: The clutchnut is undone anti-clockwise, isn't it?
Cheers, Chris
Bofs
They can be a pain alright sometimes. I use an air ratchet gun with a long extension bar through the spare wheel bracket. Failing that lie the scooter on its side so you can keep the pressure on it. And yep it is anticlockwise to loosen.
Sent using Tapatalk
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
fraserp200e
Main scooter: 1988 MotoVespa TX200
It does undo anticlockwise but there's a wee washer with a lock tab that folds down into one of the castellated bits of the nut to lock it in place.
You have bent that wee tab up out of the recess in the castleatted nut before trying to undo it haven't you?? (I've done it myself, that's why I ask :freak: )
1983 Vespa PX125
1984 MotoVespa P200E
chrisM
Thanks guys.
Yes, the washer is there, although the tabs are NOT folded over. Looks like an "expert" fitted the clutch...
The engine is out to take it to some engineering place (as I don't have an air rachtet, unfortunately).
Cheers, Chris
goldeneye
lock the clutch in place, using a holding tool, a strap wrench or strip the top end and use a con rod holding tool, get someone to keep it steady on the bench, and give the castle nut a few sharp taps anti clockwise with a long pin punch to get it going. it"ll go eventually.then use a NEW castle nut tool to undo it , old worn tools are what f@@k castle nuts up.
soulboy
i use a impact driver gets anything undone the one what u hit with a hammer
cit205
I think sip do a cosa clutch style nut replacement for early style clutches .
goldeneye
cit205 wrote:I think sip do a cosa clutch style nut replacement for early style clutches .
yeah, good shout. think its a DRT product.
chrisM
Stupid me! One of the washertabs WAS folded over correctly! No wonder, the nut resisted to get untightened...
Looks like I need new glasses!
fraserp200e
;) :roll: Like I said earlier, I've done it myself with mine, sometimes quite hard to see.
At least it's a quick, easy, cheap fix...............this time :D
1983 Vespa PX125
