mikuni tmx 35 petrol spewing out.
snowytv
running in rb 225 only done roughly 150 miles carb rubber has sheared in half,
managed to hold the carb on with one jubilee clip and slowly get home.
bought some reinforced radiator hose 38mm internal fitted it no leaks(air )
took scooter down the road for testing looked down and the rear floor runners were covered
in fuel!
petol was coming from small brass screw at the bottom of the carb and out of the overflow
opposite the idle screw,took the carb off removed the float bowl checked nothing was jammed put
it all back together still the same problem. any ideas.
Thanks in advance.
lammy 225
had same problem fri mate seems when carb turned upside down
it lets floats go on the angle,anyway my northern mate keep her of the stella
and am sure she will stop spewing out every where, shandy man back wheel for tarmack
front for air safe riding snowy bye
Tap the float bowl with a hammer a few times and see if it stops.
snowytv
took carb to bits seemed to be small amount of debris under the return valve
put it back together filled with fuel (tapped with hammer) had no problems since
thanks for info. :D
