best exhaust for Ts1
dazz-uk
whats the best exhaust to run on a TS1 225 with 34mm? giving good range throught the revs and good touring.
The last TS1 test in scootering mag had the AF / NK road pipe coming out as best overall pipe.
nelson pk
Depends on what gearing your going to use or what your current gearing is and weather you would be prepared to change it to suit the exhaust if needed.
TS1-200
corrado wrote:The last TS1 test in scootering mag had the AF / NK road pipe coming out as best overall pipe.
I can vouch for the NK pipe, good power, fitted nice, not too expensive either .....but noisy, I suppose you can`t have everything,
Keep on keepin on
Eibar
Main scooter: Eibar TS1 1966
Nk rally is great tourer got one on rapido and and rb nk mid version on the sprinter> great fit an price ,just needs silencer packing quite often
potato
soosh
Pulls 4.8 ok too?
nelson pk wrote:Depends on what gearing your going to use or what your current gearing is and weather you would be prepared to change it to suit the exhaust if needed.
Agree gearing wise I ran an Adspeed pipe last year on one TS performed well and Devtour on another there is a lot of choice out there but gearing plays a big part on your decision
dazz-uk
running a 19 / 46 and cyclone 5 speed standard box (stuart owens recomendations).
