Position of bolt in buffers when fitted in Gp forks
essexgp
Main scooter: Indian Gp200 Indian Gp Cutdown
I am in the process of fitting bolt in bottom buffers in my Gp forks to replace the ones that were in there that had been mullered. I have removed the old ones cleaned of the remains of the spot welds so now my question for you all is;
In what position do i fit the bolt in ones, ie distance back from the end of the fork or even better does anyone have a picture please.
thanks in anticipation :bouncing:
carlos fandango
I can`t give you dimensions, but if you put you fork links in place. the buffers are positioned above and below the flats on the links, put the buffers in place. then a bit of guess work as to the exact position of the holes but that should put you in the right area. or of course you could measure / template some one elses li/ sx forks :lol:
essexgp
Thanks for that, have drilled the holes and checked them against my other Gp forks and they seem in the right place :biggrin: :biggrin: :biggrin:
    Users browsing this forum: Ahrefs [Bot] and 3 guests
