Need a bit of gearing & exhaust advice
Donnie wrote: I could well be wrong to be fair but have never heard from anyone that chose a clubby on a GT kit.
Mine has a clubman on it. And it pulls 17x46 on an Li box. It's a fantastic engine.
djh66
Main scooter: 150 special
Donnie wrote:Dave, I would have thought that a clubman would strangle it a bit, after all it's a reed valve motor? (and yes, changing exhaust ALWAYS means redoing / checking jetting).
I definitely don't think that upping the front sprocket will be of benefit, I'd think it's got to be worth coming back down to a 15tooth and seeing how that goes? Failing that, a genuine Taffspeed pipe like Boxer has on his but you'll be lucky to get one of them for less than £300
I think Boxer's has been bored out to a 200 by Scooter Surgery.
Bring Me Sunshine COYH
djh66
Muttley, do you have a lack of power on hills or in a headwind?
djh66 wrote: Muttley, do you have a lack of power on hills or in a headwind?
Nope. I've got a very long third gear to use for things like that. My third gear is probably the same as a lot of 'tuned' bikes' fourth gears.
I'm also realistic about what to expect. It's a 16/17hp machine that I rarely rev past where it makes 14hp.
Donnie
Well there ya go, I'm wrong and happy to admit it. Good to know they'll run on a clubman then.
Donnie.
djh66
Donnie wrote:Well there ya go, I'm wrong and happy to admit it. Good to know they'll run on a clubman then.
:anbrgin;
djh66
What's a pm tuning expansion like? Would that be a better match, than my scootrs expansion?
I think the scootrs spanny is a 'replica' of the pm so performance is likely to be similar
servetakid
If you want an expansion pipe, I would look at an NK/ADspeed rally road, both good touring exhaust pipes. I know my rapido is a bigger CC, but it pulls well into the wind and up hills. Yours always going to loose some spred but it pulls well.
