Damper fittment ?
simonwwfc
will the bgm dampers or targa line dampers fit as a straight replacement for my escort ones . ive got a welded bracket at the top and some sort of link at the bottom its a gp125 thanks
smoore-gt225
Main scooter: lambretta GT200
hi BGM's fit straight on your normal brackets, dont know about the others though
cheers steve
simonwwfc
Does the rear bgm shock come in chrome ie spring or just black
They used to do 2 versions, one in White and one in Black, one had a stiffer spring but I'm pretty sure that they only do the Black version now.
http://www.lambrettaspares.com/spares/f ... m0026.html
You need to check your links and see if they have a stud to mount the dampers. Otherwise you'll need an adaptor bracket.
simonwwfc
ive ordered complete disk conversion as well so they are sending me new stainless all in one links for dampers :) ive got bgm chrome fronts on there way with bgm rear shock so all happy and sorted
