ss90 mudguard
blue
Anyone know what's the difference between a ss90 mudguard and all the other small frame mudguards apart from the price.
It's a lot slimmer
blue
I take it it's only the top that's slimmer?
Wayne Miller
blue wrote:I take it it's only the top that's slimmer?
The whole mudguard is slimmer, a slightly different shape and kinda goes to a point at the front.
What forks are you fitting the mudguard to?
If you going PK in a v range frmae like below then they are a b@5t@rd to fit. I had to use a 10mm spacer just to get the mudguard to fill the gap between the mudguard and the frame but when you do that it looks too high on the wheel. It doesnt look as bad as it does in the pics below but it does sit a bit higher.
Pop over to the smallframe forum theres a few threads there on how to fit one so that asthetically it looks right
Stay tuned..............
blue
I'm wanting to fit it into a set of lambretta forks on a cutdown I'm building.
Just borrowed a 50 special type mudguard off a mate which is around 180mm at it widest, lambretta forks are around 135mm inside to inside so will need to modify what ever one I use but the ss90 mudguard looks much nicer.
Lovely scooter you have there.
