Miles Per Gallon from your Scooter?
goldeneye
always used the same amount of petrol no matter what scooter ive ever had. always put a fivers worth in.
jimmo
Main scooter: Lambretta GP TS1 230 JB
TS1 230 JB Stage 2 tune, 35mm Mikuni, Franspeed Race pipe, Li150 box 16/46 - 27bhp.
Motorway use @ 75-80 mph = 6/7 miles per litre.
Around town use suspect more like 10/12 miles per litre.
Haven't got a working speedo, so bit of a guess - but base my figures on my sat nav app on my phone.
Adding the price of the oil into things makes the old girl an expensive ride!!.
Jimmo
:baddevil: :baddevil:
Eibar
Main scooter: Eibar TS1 1966
RB20 sprinter 34vhsb full bodied 7mpg <> someone else pays for the juice so will hopefully achieve3.5 mpg with a bit of work & a .rapido harry barlow 225 35mpg
potato
Solerunner1
Main scooter: GP 190
All calculated during rally runs 45-55mph constant speeds.
175, sh1/20, stock pipe(two up n fully loaded).....70mpg
Suzuki 190, mikuni tm24, indian big bore....50mpg
190(suzuki piston in a ser 1 barrel to give stock-ish timings), keihen 28, indian big bore....50mpg
i didn't know there was gonna be a test on this, or i would have kept more accurate records on all my other top end set ups. :) On rally weekends i could more accurately tell you how many miles per beer I needed.
Although not current, I had a GP150 (real, not indion) top end on a spanish 150 engine, 20mil carb and a standard exhaust, that Simon Farrel built.
It did 135mpg at a steady 50mph riding to Gt Yarmouth one year. That was early morning, which probably helped a bit.
Muttlyoo7
Main scooter: Gp200
I'm running a Rapido 225 classic with the following set up;
26mm PHBH with remote air filter,PM25 exhaust,PM Tuning X-Tech 58mm Crankshaft and SX200 gearing.
It only produces 14 BHP at the rear wheel, but cruises nicely at 55-65 MPH (GPS) and averages 60 MPG. :D
Eibar
Good MPG figures = Faggot
My advice is to ride it like you stole it and stop fannying about.
:mrgreen:
potato
sideout
All miles per 5L of fuel: (1 UK (Imperial) gallon = 4.54609188 litres, you work it out :))
Standard SX150 - 88 miles
SX150 with 175 kit, Dellorto SH1/20 and Clubman - 58 miles
SX150, 22mm Jetex and Clubman - 99 miles running in, then 89 miles
Mugello 186v4, Mikuni TM24 (airbox), Clubman, 1:5 gearing - 57 miles (rich) running in, then 75 miles
Mugello 186v2, Dellorto PHBH 28 (Ram air), JL3, GP200 gearing 1:5.22 - 45 miles (rich) running in, then 49 miles
Mugello 186v2, Mikuni TM24 (Ram air), JL3, GP200 gearing 1:5.22 - 51 miles
Standard GP200, 22mm Jetex and Clubman - 69 miles running in, then 67 miles
Avanti TT3, Mikuni TM24 (Ram air), Clubman, gearing 1:4.4 - 57 miles (just run in)
Data compiled since 2000, speedos cross checked against GPS. :ugeek:
