Vespa Winter Project
C*NTSPEED
if you doing like the bottom picture then hell yes!
GEMINI S.C.
BLACK WIDDA'S S.C.
panamesc
GLscoot
Main scooter: Vespa GS150
The scooter and body work is excellent, but why the paint job. It totally detracts the work put into the body work and engineering. I don't like the paint scheme, sorry.
Gary
panamesc
don't be sorry , it's not my scooter !
it was only for the side panel ;)
anyway , a link to this scooter
not my cup of tea but well made
http://www.rods-customs.com/forum/viewt ... 35&t=11858
GLscoot
Imagine having those skills and painting it like that. It's a great thread and how much better does it look in primer. The rear and front headlights are too big, but it is still good work. I don't like being negative about other people's work and the paint job can always change.
I need to work out how to hinge the panels. It may be easier after I have cut them.
Gary
GLscoot
Untitled by glmods, on Flickr
Just found this carb on the net. Don't know if it fits a LML engine, but don't see why not. I think it will look the dogs hazels on the black engine with the Pinasco Flytech kit. Well happy with this find, if it works.
GLscoot
I have eventually got the engine into the frame, a little tight and a bit of grinding. Had to grind a section of the engine casing away to fit the Stage 6 carb.
GLscoot
GLscoot
GLscoot
The engine is in but i think i may have a problem with clearence, the manifold is only 5/8mm below the frame, so may bottom out when i park my arse on the seat.
