Rear brake cable
chunky monkey
Has anyone tried these are they any good :?:
I'm desperately trying to figure out why kamikaze pilots wore helmets
storkfoot
Yep, I have them on both my scoots and I'll never go back to the original bend the cable kerfuffle. These ones are so much easier to adjust. Only thing I'd recommend is to change the nyloc nut every know and then, maybe once a year, as they lose their "gripping" powers after they've been adjusted a few times.
lammydave
storkfoot wrote:Yep, I have them on both my scoots and I'll never go back to the original bend the cable kerfuffle. These ones are so much easier to adjust. Only thing I'd recommend is to change the nyloc nut every know and then, maybe once a year, as they lose their "gripping" powers after they've been adjusted a few times.
agreed... fit one, you won't be dissapointed
bristolmod
they are very good. Re the nylok, I slip the original brass adjuster on as well.
Recommended
Scootering since 1968.
Bilko
Main scooter: LI150
Definately worth it.
Bilko's Oily Blog
chunky monkey
Excellent im off to buy 1, thanks for the feedback :D
Knowledge
PM me if you want one. I reckon I've sold 500, and never had one returned.
The best thing about them is the way it speeds-up the process of dropping then engine: take the nut off, and pull the inner and outer straight out the back of the crankcase.
Martin
Martin
gaz_powell
BIT LATE - BUT I`VE GOT THEM ON ALL MY 3 BIKES - EXCELLENT
As Tony the Tiger would say....." They're greaaaaaaaaat". 8-)
Ive just fitted one :bouncyeng: :bouncyeng: :bouncing: :bouncing: :smug:
God a back brake that is fully adjustable and actually works :o .
Cheers martin no problems easy to fit and adjust :mrgreen: :ugeek: :mrgreen:
