35/35 instead of 25/25
Bilko
Main scooter: LI150
Was given a Halogen 12V 35/35 bulb.
Will it cause anyprobs as it's not 25/25?
Bilko's Oily Blog
not really it might be a little dimmer at tickover
Bilko
Main scooter: LI150
Thank you. :bald:
Bilko's Oily Blog
I think all the 12 halogens are 35/35watt, well mine was. As Torchy says, the headlamp may be a bit dimmer on tickover, also it will go VERY dim when you hit the brake pedal :roll:
Does the lamp have a cup under the dip filament? A lot of these halogens don't have the cup and as a result there is no diference between main and dip :shock:
Bilko
Main scooter: LI150
coaster wrote:Does the lamp have a cup under the dip filament? A lot of these halogens don't have the cup and as a result there is no diference between main and dip :shock:
Noticed that when putting it on! :o
Bilko's Oily Blog
You can always use the rear brake to dip/dim the headlamp ;) ;)
