Yes.Muttley McLadd wrote:Why use powdercoat rather than paint?
It's a bitch to get off, isn't it?
How long do you want the paint/powdercoat job to last?
Aircraft paint stripper(nitromores? I think it's called in the UK) is the only thing I have found that will touch it. Apply, scrape, repeat, apply, scrape, repeat, apply, scrape, repeat, apply, scrape, repeat and so on and so forth.
A high heat two part steel epoxy is what can be used as filler.
