Engine studs
sydduckett
Does anyone know where i can get single engine studs for my series 3, one has sheared off and dont want to pay for the full set if i can help it.
Ta
Sef
leigh
Which stud are you after
Leigh
think i have a couple of the small chaincase ones in me garage doin feckall.
sydduckett
Leigh,
need the one bottom right, second one in. Need to get it sorted as its holding the build up.
Cheers
Sef
leigh
PM me your address and will send to you not sure if the right one but worth a try.
Leigh
dirtyhandslopez
Go to a hardware shop and get a long 6mm bolt and cut it to size. Or buy a lentgh of 6mm threaded rod and cut as many as you want.
That's not going anywhere...
dirtyhandslopez wrote:Go to a hardware shop and get a long 6mm bolt and cut it to size. Or buy a lentgh of 6mm threaded rod and cut as many as you want.
as above make sure you clean the threads out and use a flat bottom tap make the studs approx 5mm longer and use a 6mm nylok full nut and flat washer
shocky wrote:... clean the threads out and use a flat bottom tap ...
or if you haven't got a tap, cut some grooves [to collect any debris] lengthways on a 6mm bolt and wind this in. this is kinder on the alloy thread as well, they can only take so many retappings. [tip from Angry Bloke]
sydduckett
Lads, the only tap iv ever used is either in the sink or behind the bar... :D So i think ill give that a swerve...The other issue is that the engines being rebuilt oil and all so i want to try and keep it as easy as possible.
sef
    Users browsing this forum: Semrush [Bot] and 20 guests
