Honda 205 barrell?
lammer205
Hello lads i've just pulled the head and barrell of my honda205 kit it needs new rings, the barrel has the name M.Burness or M.Bunness engraved on it does anyone have an idea who it is just out of intrest?Also does anyone know if there is a measurement i can make to see if the barrel was top an tailed i have no other barrell to judge against,and if anyone can point me in the direction of a new set of rings i would greatly appreciate it .Cheers Hicksy.
J1MS
Usually shortened to 100mm... but some people stroke out the crank to 60mm then the barrels left 101mm standard length gasket face to gasket face..
RinB
I use to top barrel by 2mm and use 1mm packer to get better tranfers and mid range power
Therefore 99.5 barrel hieght based on stand 101.5
I presume Piston is off a MTX200
I have numbers as follow in me little book - Part No 13012 for the piston and 13013 for the rings
But been a while since ive done one of these
Oh also got this number for Honda part for rings 130A1-KJ1-003
Smiffy
lammer205
Cheers for the info lads new set of rings sourced the serial numbers was great to get hold off made things much simpler, Ta.So just one more thing where can i get a 1mill thick base gasket? cheers Hicksy.
maxi
Main scooter: LIS 190
Hi hicksy were did you get rings from?iam after a set as well cheers maxi
Ride it hard
there was one on ebay yesterday packer that is most places like taffsped will have them i spoke to ian on sunday and he sais they had some packers as i was after a 3mm one ring him and ask
Knowledge
lammer205 wrote:So just one more thing where can i get a 1mill thick base gasket? cheers Hicksy.
You can use a couple of standard base gaskets for a 1mm packer, but you can make one if you wish.
Take a base gasket and lay it on a sheet of 1mm ali. Spray over the gasket with a paint can and let it dry. Peel off the gasket and cut away all the ali that is painted.
A "monodex" cutter is an excellent tool for this kind of work.
Smiffy's suggestion above to increase the transfer timing is the way I used to do this conversion, and they were probably the best piston-conversion on a Lambretta barrel you could do. Simple, fast, reliable.
Martin
lammer205
Hi lads, i know some people think this is a waste of a tuned barrel kit but have any of you used a honda205 with a clubman an 22mil carb looking for jetting set-up's cheers.Maxi will look up the name of shop when i get home, and again lads thanks for the gasket advice,cheers Hicksy.
lammer205 wrote:Hi lads, i know some people think this is a waste of a tuned barrel kit but have any of you used a honda205 with a clubman an 22mil carb looking for jetting set-up's cheers.Maxi will look up the name of shop when i get home, and again lads thanks for the gasket advice,cheers Hicksy.
2 people by me use them on there sx 200,s with 25mm carbs mark wints has be going strong for over 10yrs and that included a trip to rimmini over the alps charlies needs a rebore after similar lenght of time but more miles not all honda 205,s are ported to race spec some for touring
maxi
I don't mean to sound daft but what do you mean top barrel by 2mm? :roll:
RinB wrote:I use to top barrel by 2mm and use 1mm packer to get better tranfers and mid range power
Smiffy
Ride it hard
    Users browsing this forum: Majestic-12 [Bot] and 18 guests
