disappointed with the atomic levers
sydduckett wrote:
RICSPEED wrote:are you able to swap the adjuster over from one side to the other on the pm levers ?? so if i got a pair for standard supports .. could i then convert one so i had two clutch levers ??
Sorry im a bit thick tonight, can you explain that a bit more... :?
are the levers identical and can the lever mech be swapped from one side to the other
rbgaz
lol i really dont think these were made for people with big or little hands in mind they are for adjustment of your clutch and brake travel ie set your clutch to work at lowest click then after time when u cable starts to strech ie clutch drag u can go up a number or 2 the same as geting u tools out and doing it at engine end and yes it dos work trust me
I just checked my PM levers and the answer is yes, the cable ones are reversable although a certain amount of dis-assembly/re-assembly will be necessry. The quadrant with the adjustment is marked with the adjustment numbers on both sides.
coaster wrote: I just checked my PM levers and the answer is yes, the cable ones are reversable although a certain amount of dis-assembly/re-assembly will be necessry. The quadrant with the adjustment is marked with the adjustment numbers on both sides.
thanks thats good to know as i only would have needed the cluch side .. i have an aprilia mc and adjustable levers i can get for that
    Users browsing this forum: Ahrefs [Bot], Baidu [Spider] and 18 guests
