Locking in 1st at stop
Devo McDuff
Playstation gamer tag: Devo-McD
Main scooter: Vespa PX200E Arcobaleno
How do,
Got my Series 2 Li 150 (with Mugello 186) back from the scoot shop the other day as the kickstart shaft had snapped internally. Running pretty well but since then if I try to change to neutral from 1st while at a stop it won't budge until I start moving again (or stall/kill engine). Not the end of the world as if I'm coming to a red light or whatever I just shift it to neutral before stopping but it is a pain in busy traffic and worried it might mean a bigger problem is on the way.
Any ideas what this would be?
Ta,
Dan
WINTERMODEL150
If the problem has occurred since it's been to the shop then I'd take it back.
It sounds like the clutch needs adjusting to me .
Dean
joeythescooterboy
Dan is there anything you can't break?
Nemo saltat sorbius, nisi infanus est.
Devo McDuff
Haha, nope. Got a tank I can borrow?
Very high compression, shite at starting, worn shaft teeth and a bobbins kickstart meant it was getting kicked over more than it should have done and taking a right beating. That's all sorted now though.
Timbo
Had similar , def clutch sticking..
Devo McDuff
Ta. Will speak to the shop then.
    Users browsing this forum: Semrush [Bot] and 10 guests
