Help required with led festoon bulb
C*NTSPEED
Ok guys I recently fitted an old Vespa light to my rally that I have bought the 6led festoon bulbs from sip to work the light
These are very dim and hardly noticeable when applying the brake
Is this cos my system is not battery?
Would I be better with either the three led bulbs as they bigger or the 8 led bulb cos there is more LEDs
Cheers y'all
GEMINI S.C.
BLACK WIDDA'S S.C.
purple_pill67
Main scooter: Jet200
Contacts all good? Correct voltage/ ac-dc? Facing righy way? The lammy ones are prone to rattle round so are pointing the wrong way iirc
C*NTSPEED
The light unit is brand new the bulbs are brand new.
The contacts are mint
The bulbs are the ones on the sip site and are the recommended ones
I'm just wondering if they need a dc feed to work as brightly as they should or I could have crappy bulbs
GEMINI S.C.
BLACK WIDDA'S S.C.
purple_pill67
My speedo led bulb wouldnt work on ac on my jet but is very bright once I changed to dc.
C*NTSPEED
cheers mi owd i may buy normal bulbs and see if that fails i will modify and mould in a normal bulb holder that takes a twin elemnt bulb
GEMINI S.C.
BLACK WIDDA'S S.C.
Starwave
Hello
The LEDs should be much brighter on DC for sure. To double check the LED bulbs are ok try sticking one of those square 9V batteries you get in smoke alarms across it.
SR do lots of festoon bulbs of various wattages. You might get a reasonable output by trying one or two of those.
cheers
C*NTSPEED
whos sr?
GEMINI S.C.
BLACK WIDDA'S S.C.
Starwave
Sorry bud, Scooter Restorations.
I ended up buying a few various festoons when I was running 6V in a series one, and I managed to get a tail & brake light that were puny, but not totally poo.
C*NTSPEED
ok pal cheers
do you think a normal 10 watt bulb wil be ok to use by that i mean the plastic lens in the seim light?
GEMINI S.C.
BLACK WIDDA'S S.C.
Starwave
I'd try a few wattages. Too low and they'll blow, too high and they will barely glow. Tail is usually around 5W and stop 21W but often there isn't enough power to make that glow. Try around 15W for the brake maybe? You'll probably end up with a few useless bulbs to stamp on.
    Users browsing this forum: No registered users and 60 guests
