Clubman exhausts?
Adam_Winstone
^... Crooky, what gearing are you running?
lozmondo
Adam_Winstone wrote:I've used a number of clubman type pipes over the years and I'm looking forward to the new generation of 'super' clubmans that should be arriving before too long. I currently run 2 of the Ron Moss clubman pipes on 2 of my bikes (1 on a Mugello 260 and 1 on an Avanti TT3) and have never had a standard tailpipe clubman perform anything like it! The closest that I've got to this performance and higher rev-range power delivery, where most kits are ported to produce power, was a 48mm VW AF clubman, which was the only clubman that would allow my TS1 to perform 'correctly'. Sadly, the VW clubman could not stay on because of the CRAZY noise that it made; way too loud and really nasty for road use..... really nasty!
I've run a UK tuner's respected clubman on various motors for many thousands of miles, including at least a couple of Euro lambrettas, and thought that this was the best to be had. However, it seemed to be restricting the rev range of my TT3 225 so I opted to try one of Ron's clubman pipes and the difference was staggering! I seemed to lose none of the low rev torque but my tacho suddenly showed over 1000 rpm more at the top of the range and this allowed the motor to hold on into a powerband that had previously been out of reach. Unlike many of the revvy expansions, which lose low rev torque, the Avanti clubman delivers a really nice balance of high and low power, which is really useable on the road with kitted motors.
That said, the V1 Avanti clubmans IMO lacked a few features that I'd have liked to have seen, incl. stub mounting from barrel (like any decent TS1 pipe) so that M7 stud threads were better protected on alloy kits, a method of adjusting the pipe's body position so that kits running packers could use it without being under stress, a loose tailpipe clamp and slotted underside bracket to facilitate this movement for various kits. I had to modify my V1 Avanti clubman so that I could fit it with my 64.5mm stroke Mugello and since doing so this has been extremely reliable, seeing me safely around Brittany and up through France to Belgium, then for a lengthy period of daily commuting over the summer months. What is really nice to see is that these features have all been incorporated into Ron's design for the super clubman version (produced by JL) that many of us are looking forward to.
A pipe that looks standard but performs like a good expansion, allowing kits to perform to their porting, rather than a restriction imposed by the pipe, with standard pipe reliablity is something that I am very much looking forward to. The V1 is the best clubman that I've used to date and I see the new version to offer even more :)
Christmas list sorted out.
Adam
That is really good to hear...believe the hype :lol:
my current Ancillotti pipe is falling to bits daily, so hoping something available in the time scales being quoted
crooky
Main scooter: 1960 series 2 li stg 4 175
Adam_Winstone wrote:^... Crooky, what gearing are you running?
its running a 16s front sprocket on an li125 box so about 5.3 was over geared with a 17 as you say in previous posts on other forum. It pulls nicely and gets in the powerband did try a 17 and as you say hardly got out of third in real world riding conditions. As I say just looking to get up to the 50s smoother gearing is ok as it over reved with a 15s on thanks
The man who doesn't read has no advantage over the man who can't read
Adam_Winstone
^... cool, gearing sounds ideal but, as you point out, I'm often keen to question this.... and over gearing is SO common.
Your current pipe should be fine for this setup so I'd look at other factors (jetting, timing, etc) as I'd want an AF Stg. IV 175 to be a pretty nimble beast. A pal of mine has an AF IV 175 running 5.2 and AF clubman and that will happily do well over 50mph and tour nicely.
Good luck with it.
Adam
crooky
Adam_Winstone wrote:^... cool, gearing sounds ideal but, as you point out, I'm often keen to question this.... and over gearing is SO common.
Good luck with it.
Adam
thanks for taking the time to reply think your right was gonna stick a new ron moss clubman and then get it dynod again. Its probably a jetting issue as it needs a bit of reving once i hit just under 30 in third to pick up in fourth so well worth looking at jetting it will sit at 50+ (gps) just lot of vibration and the clubman is noisy as anything its one of the new sloping af ones. I'll get it dynoed thanks again for your input
