extended lock nuts
jonbus
just bought a set of these from andy francis with the hole in them to take the lock wire.does anyone have a special way they wrap the wire round the nuts.
you wrap the wire as if you were to do a figure 8 but only get half way if you get me so that the wire keeps the nuts from unwinding .. lock wire tool is usefull .. i take it you are refering to exhaust nuts ??
jonbus
yes mate,its the exhaust nuts.thanks for the reply,twice this year the nuts have come loose.hope this set up sorts the problem out.
Any one got a pic of that? I couldn't follow all the descriptions...
I understand the principle that the wire is wound so that either nut should prevent the other from undoing but can't figure how to do it with the stub in the way...
then twist the loose ends together
Ahhhhh penny drops...
A picture's worth a thousand words, cheers.
jonbus
well 5 months later and no loose nuts :D
Monty
I have always used the figure eight locking tab washer from the chain adjuster. Cut in half with a pair of tin snips. The extended cut bit goes down the side of the exhaust flange and when tight the sides are pushed up round the nut. Never had one come loose and easy to do if its a stub fitting before fitting the barrel.
not built a lammy engine for years but hers an old one the idea was told to me over 25 yrs ago at taffspeed
Monty
shocky wrote:not built a lammy engine for years but hers an old one the idea was told to me over 25 yrs ago at taffspeed
Thats what I was trying to describe above but the cut tab needs to go down the side of the exhaust flange or the tab washer can still turn with the nut. 25 years what goes around comes around.
