suzuki 185 piston
does any have the part or model number for the correct piston a mate bought one but the ring pegs are in the wrong possition i dont have websters book to hand so cant check :bouncing:
Dell Oughta
Suzuki TS185 Piston Kit 64mm
I bought a replacment piston at style motorcycles, pudsey, Leeds using the above info (which |I got off the beedspeed site)
or you could go straight to beedspeed:
http://beedspeed.com/product_info.php/c ... ts_id/4984
Mike
cheers for that me and my mate already knew it was the TS185 piston but is it an early or a late one as his ring pegs ar in the middle of the ports were he bought it from said they will swap it for the right one if he tells them what year or model
heres were he got it http://cgi.ebay.co.uk/Piston-Kit-Suzuki ... 240%3A1318
jonny snatchsniffer
i think you need the early one, thats what i used, i dunno when the canged the piston tho, i know the wiseco ones use the same part number from 71-81 also the later one has a narrower skirt and sometimes doesnt completely cover the inlet, not a prob with a reed.
