Vespa PX Pinasco Flywheel Kit.
GLscoot
Main scooter: Vespa GS150
Has anyone bought the new Pinasco Flywheel and Stator kit. Has it made a difference? Is the wiring diagram any good? Looking to put it into a 1960's Vespa with a LML tuned engine. Probably without battery. Have you used the brake pedal switch provided or used the 12v switch fitted at the brake pedal on the scooter.
If you have fitted one could you post the wiring diagram on this post.
Thanks Gary
