how to check over a frame?
weedodger
Main scooter: Indian gp casa 185 and 200
any tips for checking a frames straightness, etc, ?
just curious as i disassemble my dry built gp, before getting it sprayed?
cheers
dapper
There's a couple of tips in Sticky's book.
warts
Main scooter: honda
I think it was Ricspeed posted a dimensioned set of factory frame drawings some time ago. You should be able to work it out from there.
I think Wintermodel on here has his own jig.
i do have those pics yes but i dont think there's enough info on them to be of real use but i will post again no probs ,
as dapper said i'm sure in stickies book it does give basic measurements between loop and headstock ..much more than that you rely on sighting the frame a various angles .. if still not convinced its a jig mate
you say its dry built .. if you can take it on a test ride that will help .. if it feels right it will be .. a bent frame will tend to twitch or feel like it wants to drop when cornering in one particular direction
the critical areas are headstock and engine mount ... look for visible stress points on the frame particularly at the bend forward of the front struts and around engine mount .. good idea is to weld on a servta style gusset also especially if you are fitting a hot motor ...
did you have any issues fitting panel work ??
weedodger wrote:any tips for checking a frames straightness, etc, ?
cheers
you have neglected to include your area/town/city in your profile ........... there maybe someone close to you as there are 5/6 people with frame jigs and one about 15 miles from me
