Gp150/Gp200 slides
CPH Lambretta
Main scooter: DL 150 1970
I can see that Italian GP 150 and GP 200 have different slides, but whats the difference between the two? Is one richer or leaner? Any info greatfully recieved.
Cheers Nick
Slow is the new fast!
yes ,the larger the cut away /the leaner that slide.
CPH Lambretta
Hi Sean, thanks for the reply. Do you know if the 150 or 200 is richer?
The 200.
Special X
The (richer) 200 is flat on the engine side wheras the (leaner) 150 has a cutout on the engine side. If you're using a 200 slide you need to use a200 atomiser as well.
