Best degreaser?
warts
Main scooter: honda
Petrol is dead iffy as a cleaner. It does clean well but the flash point is so low to be dangerous. Too many sources of ignition in a standard shed/garage. Even empty cans can explode.
Parafin/Diesel works ok but watch your skin as you can pick up dermatitis if you're sensitive.
There are safe cleaners about which aren't too pricy if you buy a reasonable amount, (you can store them safely too) and have the advantage of not poisoning you and will dry properly rather than leave a greasy residue.
skidmark
I use WD 40, I buy it from Screwfix in a 5lt container it also comes with a spray bottle, I use it for loads of stuff as well as cleaning engine cases, coating scoots for storage or riding during winter, I keep my engines cases covered in the stuff and it keeps them in great condition and easier to clean.. ;)
fairspares
50 / 50 % white spirit / petrol is excellent for cleaning muck of engines and killing weeds , grass and flowers.
goldeneye
take the engine to the local garage and stick a quid in the jet wash...leaves all the muck at there place. finish off with some gunk and WD40.
Eibar
Main scooter: Eibar TS1 1966
unipart"formula traffic film remover"
5 gallon drum about £20.00, brilliant engine degreaser, we use loads of it and its brilliant.
or get it off ebay
potato
Rotor
Main scooter: 1960 S2 Italian
skidmark wrote:I use WD 40, I buy it from Screwfix in a 5lt container it also comes with a spray bottle, I use it for loads of stuff as well as cleaning engine cases, coating scoots for storage or riding during winter, I keep my engines cases covered in the stuff and it keeps them in great condition and easier to clean.. ;)
Same here use it on the car engines too, works really well and leaves a film so no rust after, where as a degreaer leaves clean metal to corode
P.
Eibar
WD40 (water displacer 40) aint a degreaser its a good cleaner and protector but not a degreaser.
potato
Spanish Fly
Main scooter: P200e
Eibar wrote:WD40 (water displacer 40) aint a degreaser its a good cleaner and protector but not a degreaser.
I guess if I does a good job it doesn't matter what its classed as.
The absolute best 'degreaser' I've ever used is Mr Muscle Oven Cleaner. A bit extreme for the OP's requirement but f*~*ing awesome for shifting baked on black sh*t. Just spray it on leave it for 10 mins, no longer on ally, and wash it off. Simples. I've tried white spirit & parrafin with help of scouring pads or wire brushes and they don't come close to Mr Muscle! Cheap too.
SF
