front park light comes on with brake light
soulboy
fitted twin rear lights but when light are off and i apply the rear brake the front park light also comes on HELPPPPPPPPPPPP :wtf:
WINTERMODEL150
soulboy wrote:fitted twin rear lights but when light are off and i apply the rear brake the front park light also comes on HELPPPPPPPPPPPP :wtf:
Sounds like you've got the wrong bulbs fitted to the rear lights or a poor earth,take the rear bulbs out then apply the brake and see if the front park light then comes on,if it doesn't come on then you're in the right area check the correct bulbs are fitted.
Dean
soulboy
its not the earth .and ive tried it with the rear bulbs out and it stops but they are the correct bulbs any ideas thank full of
lambro
It normally means you have a stop/tail bulb holder (two prongs in the bottem) on the rear and have fitted a bulb with a single 'foot' on the bottem.
Therefore when the brake is applied it puts power through to the posistion lamp circuit.
Shaun.
