Improving Lighting?
servetakid
The lights aren't as god awful as I made out. The loom is casa but the switch wiring is original serveta. I'm just after a more concentrated beam TBH.
The answer to that is for someone to redesign the reflector as per the late PX range.
Train Driver
24v 3w speedo bulb stopped my speedo acting as a landing light :lol:
rbgaz
what about the reedspeed exon bosch fitting bulbs i hav one very good they come in blue and yellow was good writeup in scootering i think last year
http://www.ekmpowershop2.com/ekmps/shop ... 2265-p.asp
mnpes
Doesn"t really matter what type of bulb or wattage you put in a lambretta headlamp
The unit-reflector design is not up to parr :(
I use a 55/55W - H4 halogen in one of the gp"s ~ Fully dc - 11ah battery fitted
Bright ~ But the beam concentration is poor ~ Even when aligned correct
For safe-fast night riding I use a lucas fog ranger spotlamp fitted with a halogen ~ Not the headlamp
The fogranger"s are bigger than the Pathfinder"s generally fitted ~ They give a better light concentration
When it"s foggy instead of the spot use the foglamp ~ Again ~ Far superior than the standard lambretta headlamp
Using the lucas lamps going over the unlit Whitby moors certainly make me feel a lot more @ ease ;)
~ ~ ~ AKA ~ INSPECTOR GADGET :moon:
vRSG60
Main scooter: Lambretta Li125 Lambretta GP20
rbgaz wrote:what about the reedspeed exon bosch fitting bulbs i hav one very good they come in blue and yellow was good writeup in scootering i think last year
And last a few months, other than that excellent.
I get my kicks out on the floor.
rbgaz
ive had the reedspeed one since they came and still on same bulb and its on all the time the beedpeed one i found to be very poor and had two in matter of weeks
vRSG60
My ,istake. I got mine off EBay. Not sure who.
Eddie15b
Main scooter: gp200e
mnpes wrote
"For safe-fast night riding I use a lucas fog ranger spotlamp fitted with a halogen"
is this the one listed below ? if so how did you mount it?
http://www.vintagecarparts.co.uk/produc ... -spot-lamp
"When it"s foggy instead of the spot use the foglamp"
again is this the one listed below ?
http://www.vintagecarparts.co.uk/produc ... -lamp-5wft
so a pair of 55w lamps and a normal lammy headlamp will be sucking a lot of juice wattage wise
how did you wire them up?
i take it your using a 120 watt bgm stator and a DC wassel conversion
cheers eddie
    Users browsing this forum: Semrush [Bot] and 11 guests
