Improving Lighting?
servetakid
Right winter is around the corner and the nights a drawing in, I've been for a fee evening ride and I've found my Speedo light to be brighter than my headlight!!
So what can I do to improve my headlights power? I've put an LED bulb in the rear light, but what's the best halogen conversion for a lambretta out there?
Thanks
Boothy_the_makem
Playstation gamer tag: Phantomkiller_uk
Main scooter: modded t5 classic wi a parker
Echo
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
What's your current set up?
The simplest way to make your headlight brighter than your speedo one is to remove the speedo light.
servetakid
Haha, that's one way around it!
BGM regulator and BGM stator with a bog standard headlight set up.
Muppet
Muttley McLadd wrote:What's your current set up?
Haha......... :lol: :lol:
C’est la vie
Boothy_the_makem
Snigger :bigsm:
purple_pill67
Main scooter: Jet200
Wassell DC conversion.
Bgm led rear, led speedo bulb and get an old headlight junction box to butcher up to fit a H4 conversion block. Jobs a good un
Adam_Winstone
You lights should be perfectly good if all is well elsewhere. Providing the BGM stuff is working correctly then I'd consider fault finding other elements of the lighting system. First one to check is that you've got the tail light wired up correctly as you'll lose much of your headlight power if the wrong filament (brake light) is constantly lit when the lights are on. Could also be a poor earth, etc.
Adam
ArmandTanzarian
A knackered reflector in the headlight will lose a lot of power too.
ArmandTanzarian
purple_pill67 wrote: to fit a H4 conversion block.
Does anyone sell these ready made?
    Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 6 guests
