Vespa Cross
makaman
Main scooter: vESPA gtr (oil pumped)
hi,
I present to you the PKross...
on a base of pk 50 automatica
engine: Polini 133 reworked, HP4 ignition, exhaust Polini evo. reworked, 24 dell'o PHBH carb, manifold 24 polini
more informations & joining us on:
https://www.facebook.com/groups/VESPACROSS/
:fb:
Mel K
Potentially, that looks like great fun, I had something similar years ago but mine had the benefit of a sidecar type thing on it, made flying around corners in a drift like fashion so much more doable and fast.. Used to see everything off on the bends, not so much on the straight but was great. :D
makaman
Mel K wrote:Potentially, that looks like great fun, I had something similar years ago but mine had the benefit of a sidecar type thing on it, made flying around corners in a drift like fashion so much more doable and fast.. Used to see everything off on the bends, not so much on the straight but was great. :D
I think I've eva seen it...
did you make a post on this forum??
thanx
Mel K
Might have mentioned it but sadly no photos, it was a small frame with a ss180 engine, headset and forks, the chair was on the right to accommodate the weight of the engine which also helped to keep it on the ground. You could go full throttle into any bend with you and the chair rider leaning right over to make it turn. It was the best fun on any scooter ever. 8-)
makaman
here is the manifold welded (thanx to my very-good welder from the firm I'm working: EUROCOPTER)
:nerd:
makaman
Hi dudes!
new pics in SUPERMOTO mode
bye :bouncing:
wax
All it needs is a Falc kit..........Brilliant!
makaman
Hi all!
some newz from the project...new engine (px) new exhaust,...
and a new cylinderhead VRH pro by PINASCO
BYE
join us & follow :
makaman
wax wrote:All it needs is a Falc kit..........Brilliant!
thanx!
it won't be a Falc, but a 177 polini reworked, pinasco VHR pro cylinderhead, a 32 vhsa carb & a Arrows (DTR 125 ymaha) exhaut modified :ugeek:
OzOAP
Main scooter: Vespa PTS1E
Got this sitting in my garage. Would love to drag it round a field again sometime.
I dont do facebook so could stuff of any interest be posted on here?
SBW event a few years ago
