t5 kegra 190 or malossi 172
soulboy
oooo its yours is it al as told me about your engine im considering that just with matched caseings and a good pipe (as i dont have a grand )
C*NTSPEED
seriously if you just want a quick reliable rally going scooteh then just get a malossi 172 its tried and tested when mr barlow did mine we spoke about the 205 special he done for scootering and he said all that time and money for little gain over the 172.....the jb and kegra and mbd are full on tuned motors which cost money to dio and money to run and very expensive when broke....i miss my 172 dearly and im hankering again for another one anything that is just bolt on and works out of the box and pulls my fat arse is a hands up as far as im concearned :fb: :fb: :fb:
GEMINI S.C.
BLACK WIDDA'S S.C.
soulboy
your bang on right again joe ..no messin with the malossi and a 21 tooth clutch good pipe and dont think there will be a big differance do you mate :fb:
C*NTSPEED
no mate i used a 22 toothed clutch with taffspeed pipe....oh the days........ soon as i get chance im gonna build me another one keep it on standerd carb pal no need for big juicy carbs tha nos
GEMINI S.C.
BLACK WIDDA'S S.C.
soulboy
i didnt think the t5 would pull a 22 tooth i bet that was a real mile muncher .... right at the min i have a stock top end but as far as i can tell all ports are matched and inlet matched to carb ..so if i get a 21 t cosa clutch and a pm pipe what would that be like me thinks quit good :?: :?: :?: :?: :?:
bazman
Bin the PM exhaust you'll spend more time in 3rd than 4th!!
roadrunnerian
try the sip new lhs pipe or a rhs jl pipe the pm pipe is a very rev pipe you have to be at 6000 revs to start feeling the power band.
C*NTSPEED
personally id try to find a taffspeed prooven pipe even the remade ones are very good imo
GEMINI S.C.
BLACK WIDDA'S S.C.
soulboy
cheers fellas i was just gonna by a pm as well i have a simo on it at the minute at the engine seems to like that ..it just runs outta steam on the top .so a 21 tooth should cure that HOW GOT ARE THE PINASCO PIPES
C*NTSPEED
pinasco pipes are only just better than the simmo if you on a budget get a rh revolver pipe they are based on the rz mk1 just one of the cones is slightly shorter to aviod patent rules :-)
i got one on the wildthing and my polini 208 seems to REALLY like it
GEMINI S.C.
BLACK WIDDA'S S.C.
