FAG N205E bearings
bristolmod
What application do these bearings fit? Its similar to the FAG NU205E, except the OUTER ring is separate. (the NU205E has the INNER ring separate and fits the flywheel side in the mag housing)
Any thoughts Gents? Someone did say that it was for Series 1's
Scootering since 1968.
Donnie
yep, it's for the series one assuming it still has that particular mag housing still, and I believe some early series 2's had them too. You need to fit these with an extra distance washer too if I remember right?
Incidentally I think it's also used on vespa rally models too.
Donnie.
bristolmod
thanks for that Donnie- I've found 3 unused ones still packaged up. Is there any market for them or have most S1 owners gone over to the later type of mag housing?
Omg :shock: :shocking:
Are they NOS?
bristolmod
NOS as the day they rattled off the FAG production line...................................
