Lambretta Flywheel Woodruff key sheared in half
- drunkmunkey6969
- Moderator
- Main scooter: '69 Lambretta GP
Only 40ft-lb?
only 50 for a flywheel tas got humungus inertia; for a wee AF jobby lapped in 40 is the new 50 they do have weedy little bosses that can get mangled if over tightened yup thinks Me like 40 many times more than 50,
muppet,
muppet,
C’est la vie
- coaster
It used to be a fairly common problem back in my youth when nobody owned a socket set let alone a torque wrench
All I had was a selection of box spanners and a bent screwdriver
As per adam's list, I'd get a magnifying glass on the flywheel keyway just in case it has cracked.
warts
- Main scooter: honda
When wiped clean after lapping, you should see a matt grey surface all over where the flywheel goes on the crank, and the same inside the flywheel itself. If you think its right, try it with layout blue/marker pen, there should be no high spots.
A correctly fitted taper should work without excessive torque on the fastener.
- drunkmunkey6969
- Moderator
I'm a big fan of the AF light flywheel, I use them more than any other type. I always torque to 50 ft-lbs and have NEVER mangled a boss, nor sheared a woodruff key by doing it this way. Seems to work OK for me.Muppet wrote:only 50 for a flywheel tas got humungus inertia; for a wee AF jobby lapped in 40 is the new 50 they do have weedy little bosses that can get mangled if over tightened yup thinks Me like 40 many times more than 50,
muppet,
Same flywheel, and now running OK.
However think i will get some grinding paste and do a proper job.
Can I simply do with crank in position ?
when you refit the new key, take some time and lap the crank to the flywheel it makes sense, last time i sheared a key (about 79) i cut the corners off a sixpence with a pair of pliers and a brick as a hammer and wedged two bits in. it got me home to newcastle from bridlington <(i think), ever since then i have lapped and its never happened again in tens of 1000s of miles,,PS make sure everything is spotless when you refit flywheel, no paste anywhere !
- sean brady scooters
- Dealer
definatly lap crank to flywheel and torque down to 50 f/lbs
Spanish Fly
- Main scooter: P200e
What's a Challenger 240?stokky wrote:
Challenger 240,
SF
- Special X
- Main scooter: Lambretta 125 special 230cc
I'd totally agree with a "proper" flywheel, but 40 lb/ft (using the same halfords wrench featured in last months scootering) stretched the boss on that flywheel.sean brady scooters wrote:definatly lap crank to flywheel and torque down to 50 f/lbs
PS the challenger was a project that involved chiselspeed.
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
