t5 cylinder porting
jackskater
Main scooter: vespa t5 millenium RAT
hi has anyone ported just the topend of there t5 piston and barrel if so could they tell me thier result and maybe post a few pictures so that i could copy it lol :frog:
roadrunnerian
stick a kit on you will get better results,malossi 172 ,polini 152 try the new sip style sito plus exhaust it is suppose to add power even cheaper ;)
cezeta
roadrunnerian wrote:stick a kit on you will get better results,malossi 172 ,polini 152 try the new sip style sito plus exhaust it is suppose to add power even cheaper ;)
i ordered a sip road ages ago but they are never in stock for the t5 :roll: im tempted to buy a normal one and have the flange welded on.
paul d
Main scooter: T5 172 Tv 240
Its not piston and barrel porting but when you open scooterotica homepage there's a good picture of a nice T5 barrel with opened up transfers . The picture flashes up on the screen with many other examples of fettling work and only stays on the screen for seconds but if you could find that picture on the site it would be a good start I'd say .
Knowledge
Many years ago (22), I machined a millimetre off the top of the barrel, and put a 1mm spacer under the barrel. This increased the transfer timing and the exhaust port timing.
It made no difference what so ever.
Well, you asked.
tony
Main scooter: 90ss
I have done a few but fitted to my smallframe motors. If you look at my 90ss thread in "show us scoots" one barrel is there. The T5 barrel is the best barrel Vespa ever produced by far. It does have potential but it does need a decent pipe to make the ports efficient if you start opening things up. You really need to look at bespoke pipes and this gets expensive.
cezeta
jackskater
been chatting to my mate who does smallframe sprinting etc and he reckons he can get a lot more out of it by also porting the cases, whilst replacing all bearings and seals etc has anyone done this before or would i be the first person to have done this or has it been done before but with no significant difference made to performance.
tony
Main scooter: 90ss
Who sprints a smallframe jack? Would I know him?
gimp1971
ive had exhaust port opened on my 172 and timing but not really done anything on it since being done so cant comment lol
    Users browsing this forum: Baidu [Spider] and 1 guest
