Hole Dimensions For Carb
Bilko
Main scooter: LI150
That's a nice hole, do you mind if I use that idea?
Bilko's Oily Blog
craze01
Nonot at all! its a tax disc holder cut up and used as a template! If you want close ups I will get you some tonight mate!!
Bilko
Main scooter: LI150
Done. Used your idea of the tax disc for the template for the hole.
It was easier than I thought due to the carb rubbing against the panel and this gave me the point to use for marking and drilling.
When I get back home I'll post pics of how hard the carb was rubbing against the side panel.
Bilko's Oily Blog
Bilko
Main scooter: LI150
Never checked closely the paint removed from inside the panel.
It was bad, the carb rubbed hard enough to put grooves in the metal. :oops:
But at least I knew where to cut the hole.
Just need to tidy the hole up a wee bit more.
I can't use the disc holder because of the curves in the side panel
Thanks for the help troops.
Bilko's Oily Blog
vegansydney
Sorry to hijack this thread but what is that seat in the GP posted above? I like! :D
Bilko
Main scooter: LI150
I'll find out for you.
Bilko's Oily Blog
TheSeeker
I love this scoot.
Just the right mix of well used/well maintained/not too bothered about winning any custom show prizes.
Going for the same philosophy with my rebuilt Li.
Great stuff.
Ben
Bilko
Main scooter: LI150
Thank you very much. It does look a lot worse in the flesh and although I was a bit embarrassed about the state of it. The positive posts in the show your scoot pics forum changed my mind.
Bilko's Oily Blog
dapper
Bilko, can't you "persuade" the tax disc holder gently to the curve of your panel??
Bilko
Main scooter: LI150
No mate, the curve too sharp.
I'd need to find something very flexible. :?
Bilko's Oily Blog
    Users browsing this forum: No registered users and 40 guests
