Engine mounts.
10 inch Terror
Xbox live gamer tag: No.
Hi all,
I'm about to start building up a GP200 casing and have a quick question. I'm going to be building either a RB 225 or 250, so i'm going to want some good quality ones. What are the best mounts to use? Will SIL direct from a reputable source be ok? I've seen them range in price from £20 a pair to £50. Any advice or comments very welcome. Cheers Pete.
I'd also be interested in some recomendations, I had a set of cheap ebay 2 hole mounts which lasted for the Spanish and Irish Euro trips. The left hand side one had deteriorated so I replaced them both with a set advertised by a high end UK dealer as being the best available in the world which lasted less than 1000 miles. I'm running an Avanti 225 at the moment and will be fitting a Reedspeed extended mount on the kickstart side as per Ron's recommendations.
10 inch Terror
I went with genuine SIL ones from Scooter restorations.
