4 pole stator plate non battery
PanosK
The video is crap as it is from my mobile
http://www.youtube.com/watch?v=ipDkYjSdA-g
http://vespaclubvolos.com
http://www.lambretta-club.gr
firekdp
Fix the pink to a good earth on the engine, kick over and try for a spark. If you do not get one I would put money on the problem being the condensor. The tests you have done prove that the points are OK, and as the pink is sparking to earth then the coil is OK.
Just watched the video :D . That is still too fast, you should be doing it very, very slowly.
PanosK
Thank you very much for the help.
If there were not people close to my Lambretta I would do it now.
We will see in the morning.
Thanks again.
PanosK
I need to express my gratitude to all og you and especially to firekdp .
THANK YOU KEVIN I just fired her up today. :)
