Mugello 186 piston shims
jrm
Main scooter: Li 125
Regarding fitting mugello 186 kit,i've fitted new crank & bearings am on to piston.Do i need to fit piston shims as there is quite a gap between small end bearing & piston(approx 3-4mm).The crank is not shimmed.
how much sideways movement of the rod is there at the big end ?
jonnyb
Main scooter: Li150 Special
Might be worth buying a wider small end bearing assuming your crank is shimmed, Cambridge lambretta have them in stock I think :-)
Gazbo72
Main scooter: SX200
jrm wrote:Regarding fitting mugello 186 kit,i've fitted new crank & bearings am on to piston.Do i need to fit piston shims as there is quite a gap between small end bearing & piston(approx 3-4mm).The crank is not shimmed.
Doesn't using shims or not depend on the crank that your useing ???
jrm
Thanks 4 replying Byron.Just measured 1.3 -1.4mm.
Gazbo72
Main scooter: SX200
My last post sounds a bit daft . I have just fitted a GP200 crank with the large gap at the little end bearing. Reading sticky's book it says this type of crank doesn't need shims.
jrm
BUMP
    Users browsing this forum: Baidu [Spider] and 2 guests
