Forever Tinkering
mnpes
Been tinkering round yet again :roll:
Had a spare 200 barrel setup and wondered what would happen if a feed was added from the exhaust outlet via drilled holes aligned in the piston skirt ~ Started off with 2 x 2.50mm holes and have now stopped @ 2 x 3.50mm ~ Don"t want to go any bigger as there is strong possibility it will begin to be a pig starting
Can"t say there has been any power increase @ all ~ But egt readings definitely lower @ speed
Anybody else done or know of any information on this " tinkering " ?
To much time on your hands Alan :D ..good to see you at York
holes in the exhaust side skirt ??
bristolmod
this needs clarifying methinks. I always put a couple of holes in the piston skirt either side of the swept exhaust port area to aid cooling.
Is this the same thing?
Chris
Scootering since 1968.
