Hi all, I understand you can buy something to stop tanks leaking? I've just fitted a long range tank but it has a slight leak n one of the seams.
Any recommendations please?
Cheers :fb:
Petrol Tank Leak
warts
- registered user
- Main scooter: honda
- Contact:
If its not been used, would it be better to have it welded? By the place which supplied it? It could be fibreglass or secondhand I suppose. Recently discussed:
http://scooterotica.org/forum/viewtopic.php?f=6&t=22817
tbh .. i find tank seal to be a last resort solution .. if its new send it back .. second hand then far better to get it welded
shureimage
- registered user
- Main scooter: SIL GP200
- Contact:
This I what I used a while back Russ, http://www.frost.co.uk/por15-tank-sealer-473ml.html
- DigDug
- registered user
- Main scooter: Lambretta
- Contact:
As advised already get it welded it will only get worse.
I used this stuff that lasted for 18 months
http://www.creatrix.co/index.php?dispat ... oduct_id=3
Then I got it welded - same chap that supplied it - top fella did it FOC!
Did you have to do that?
- Toddy
- registered user
- Main scooter: Lambretta Series 1
- Contact:
Good ideadopeshots wrote:Cheers Guys, it is new so I'm gonna return it once my other one turns up. That will teach me to buy cheap off eBay!
Is it 1 of the stainless standard looking long range tanks? IE with the lip? I've seen a lot of these including my own, and all had cracks or some other defect. As others have already said, welding is the best permanent solution, preferably TIG.
All but 1 had cracks in the tank where the fuel tap thread is fitted. I took 1 back to a dealer only to be offered 2 more with the same defects, so I got a refund. I then bought a second hand 1 for half the price and repaired it.
