Another near death Lambretta experience !!!
KCB
Perhaps a bit of an exaggeration but none the less.
I thought the rear handling felt a bit odd on the way home from the Big 7 rally only to find this:
The spring has snapped on the rear shock.
Any point replacing the spring or is there now a better recommending rear shock available?
Cheers.
From a cost effectiveness point of view replacing the spring will be far cheaper than buying a new shocker...
Which spring was you using 180lb or 220lb, their is 2 guys who frequent the forum who will be able to both to sort this for you, Chiggy and Shocky, just do a search..
warts
Main scooter: honda
Has the spring been shortened?
You can get the springs (or could, anyway) from Demon Tweaks for next to nothing.
The 180lb ones you can put in by hand. 220 might need a few bits of string to hold it together while you fit the top bit.
KCB
No the sprinig hadn't been shortened, well it is now as a couple of inches broke off.
If I didn't want to replace the spring and instead get a new damper (not sure if I trust the R1 any more) what would people recommend?
Cheers.
Andy Pickering wrote:
Thats Chiggy
I know, just trying to be helpful for the googley challenged... ;)
Googley challenged lol..
All depends on your budget really..their is plenty on the market ranging from £100 -£300 i reckon
Sent from my GT-I9000 using Tapatalk 2
WINTERMODEL150
Got a taffspeed on the rear of mine ,its been on there for a few years now still looks and works as good as new
Dean
