30mm carb setup on 177 polini
Ivan_200
Main scooter: Vespa PX125/177
Can someone tell me the initial carb jetting on 30mm OKO (keihin copy) placed on 177 polini kit with rotary intake? Just so I can fine tune from that point. Thnx ;)
Ivan_200
No one? :mrgreen:
goldeneye
not a very popular carb used over here ivan, most people used Dellorto.
gaz_powell
A start with a expansion on would be :-
Main 128 going down on plug chops etc probably to 125
pilot/idle 40 going down probably to 36
needle JJH (standard)
clip 3 adjust as required
slide 3.5 (standard)
Check out ScootRS website - there is good info about needle sizes - i think they jet kits with a range of needles, mj`s and pilots
Ivan_200
Thank You for the answer! ;)
