RAPPIDO 225 CLASSIC CARB SET UP
col68
- Main scooter: lambretta s2 li225 ts1
Now mate i had that set up but a jl3 pipe 55 idle, 40 slide, av266, x7 clip on 2nd from bottom , 128-130 main. If scoot stutters with 130 flat out try 128 main cant be far off check plug colour should be a nice chock brown . Had a ram air filter on :fb:
dsc scotty
Also use a 300 fuel needle valve!
+1,tried a 125 main bogged slightly so have dropped down to a 122tony81 wrote:i have same set up 40 slide 70choke 55idle x7 needle (second clip down from top)av266 122main runs very nice also try open mouth carb then put a filter on filter slightly slows it down.
- Information
Who is online
