2 stroke leak
ive got 2 stroke oil running down the back of the cases,looks to be comming from the black rubber thing with brass thing sticking out,wot is this???,or from under the bowl below it,could have fuel in the oil as its cleaning the case as it leaks,simple answers as new to this,thanks
- LI150
- Main scooter: Series 2 LI150
Brass thing is your air mixture screw.
It will be petrol mixed with 2 stroke oil leaking. Now for the causes.
1.Float valve needle worn and leaving petrol turned on so float bowl always filling slowly and thus leaking out the carb and via the mixture screw down your engine.
2. It could be just spit back from carb
3. Carb gasket leaking
These are the main causes in my experiance hope it helps..
Thanks,will have a go today.
just had a look in the carb,bowl is holding some 2 stroke collecting at the back corner,help please or clues,thanks
the carb and box are at a slight angle so any petroil will collect at the back - the petrol will evapourate leaving a deposit of oil behind - you will get some petroil in the box as stated earlier from spit back - remove the filter and clean thoroughly, remove and clean carb, remove carb box and lap the bottom, like LI150 said renew both gaskets (to box and carb) and replace the float needle.
careful not to over tighten the carb on removal - you said it has brass mixture screw you will need to remove this to get the carb off - carefully wind it full in noting how many turns to full stop - then screw it right out before you remove the carb- when you reassemble screw the mixture screw right in and unscrew out returning it to the original setting
the brass mixture screw should have a rubber grommet aswell
its nothing to really worry about and its an easy fix
best of luck
best of luck
