Repacking JL end can
I want to repack the muffler on a JL, curly type.
I need to drill out the rivets, but as i am bound to get it wrong if i guess, which end does it come apart from?
rosscla wrote:I want to repack the muffler on a JL, curly type.
You only need to remove the end cap, use the blanket typ material and wind it round a piece of pipe (I used some plastic waste pipe) the same dia as the ceter pipe and slip the roll onto the center pipe and inside the can. Stuff it in as tight as you can and rivet the end cap back on. The rivets I drilled out were only ally so that's what I used to replace them. Whole jobe took 30 mins start to finish.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 66 guests
