S3 ignition switch
muffster
Xbox live gamer tag: muffinator233
Main scooter: LI 125 S3
Hi folks.
I want to put an ignition switch in place of the push button cut out on my S3.
My question is are they easy to wire in. There are a few on ebay but i don't know which sort to go for or how to connect it in.
I've got the original bulb holder and a good quaility handlebar switch which was a doddle to sort out.
Can anyone help with wiring one up, i'm not sure if they even come with colour coded wires.
Thanks.
purple_pill67
Main scooter: Jet200
Go for a casa one, the indian ones dont last....the keys are made of toffee and the barrel breaks-had 2 go on me. 1st was fitted when I got bike and 2nd cos it was all I could get the same day.
muffster wrote:Hi folks.
Thanks.
Simple enough if you only want it to turn off the engine as only one wire is involved. However, even thoght the switches are colour coded the colours used are inconsistent and can't be relied on. Also, a lot of the switches on ebay, espeially the cheap ones are made of cheap materials and will short the ignition out. The ones availabel from ScootRs are fine as are the slightly more expensive ones from MB Developements. The Casa ones are said to be good but are very expensive by comparison.
sideout
I've gone over to using the Honda ones as sold by ScootRS. I managed to pick up another second hand from Ebay which fitted straight into my Li headset. I presume the Indian "KAC" ones are called that for a reason?......
Muffster, put your location in your profile, then you might find someone locally may offer to help :idea: ;)
If you get stuck I've mapped the connections for both types of ScootRS type switches and can forward them :)
muffster
Profile updated!!
I want a decent switch to replace the cut out and for some security.
I can't find the switches on the scootrs website but i would appreciate some info on the connections.
Many thanks.
This one?
http://scootrs.com/moreinfo.cfm?Product_ID=744
sideout
http://www.justlambretta.com/ look in the electrical section...
F004 - is the Li conversion switch, but out of stock at Just Lambretta
F014 - is the one I use as a replacement ignition switch on my GP
Are any of the above switches a direct replacement for the kill switch or does the aperture require opening up to fit the switch through?
purple_pill67
soulsurfer wrote:Are any of the above switches a direct replacement for the kill switch or does the aperture require opening up to fit the switch through?
I had to file my spanish headset slightly to change the orig kill switch still fitted to the casa one I had...not much and didnt affect the look/paint once the ring was screwed on.
sideout
Mike, the F004 on Corrado's site is supposed to be a direct replacement, although they've been out of stock for a while and I managed to get one on ebay (albeit a tad gnarled as the guy tried to install it with Stilsons. :roll: )
No filing involved here :)
I took a couple of photos as I've got the headset off to fit a SIP speedo.
